Re: 300u Power Steering
Red Rider
12-21-2001 19:02:40
Dennis! I have a 300U that I put power steering on. As previously posted there are several parts that you will need. The steering gear box contains the sensor and hydraulic assist unit. The Steering gear box is the same for the 300,350 and 460 and maybe later utility tractors use the same unit. The one that I used was off a 460 utility. The hydrotouch regulator valve off any IH 300/350 Utility or 300 through 450 farmall with power steering are the same. It also makes a difference if you have one hydrotouch valve or three. If you don't have a hydrotouch manuel or a parts manuel then you should get one. These two manuels show you everything you need to know when converting from manuel to power steering. If you have anymore questions post another request for help.
