Farmall 340 value?
Curt
11-18-2001 17:24:22
I've just found a Farmall model 340 with a Paulson loader and a back blade. As near as I can tell from the serial number it's a 1958. The tires are fair with a bit of checking. The sheet metal is good with a few small dings. The paint is faded badly as the tractor has been out in the weather. There is a small piece of sheet metal missing from the lower part of the dash. It started right off and sounds good when running. The steering "catches" once in a while while driving it. Is the asking price of $1000 fair?
Steven
11-19-2001 07:53:25
 Re: Farmall 340 value? in reply to Curt, 11-18-2001 17:24:22
Tell me where it is then you won't have to worry about spending too much!
FC
11-19-2001 07:14:23
Better grab it up....if you subtract the value of the back blade, and loader that does not leave you with much at all in the tractor.
Douglas Stockman
11-19-2001 03:19:55
OK, where is the tractor located. If you do not want it, I know someone who would love a 340 for $1,000!
Douglas Stockman
Penfield, NY
J.D. Humm
11-19-2001 02:38:21
Sounds like a bargain to me if it runs good and has a loader.
Curt
11-20-2001 00:26:28
 Re: Re: Farmall 340 value? in reply to J.D. Humm, 11-19-2001 02:38:21
Thanks fellas....I asked around a bit from some locals and also checked out all the info I could find at the YT site. I went and picked the old girl up. I figure to keep the snow removed with it this winter and then in the spring I hope to get it inside for starting restoration. It sounds like parts might be hard to come by.
J.D. Humm
11-20-2001 02:43:37
 Re: Re: Re: Farmall 340 value? in reply to Curt, 11-20-2001 00:26:28
As far as the steering catching I have a 504 with a loader. The 504 is basically a souped up 340. I had to overhaul the steering gearbox. The seal had started leaking and let the big bearing go bad. I blamed the extra stress from the front end loader on a tricycle front end for creating the problem. I then put on a new Schwartz wide front end which transfers all the stress to the tractor frame rather than the gearbox. Good luck with your tractor and your restoration project.
