'48 M need info
Busch
11-12-2001 15:43:57
Another dumb question from a want to be. I have a M with a wheel on the side that grandpa used But I probably never will when I restore the tractot I will keep it there but in the mean time should I take it off to keep it out of the weather? What is it made of and what is it called. I also need to know if there is a way to tell if this tractor has hydraulics. I have two pipe fittings on the left hand side that are capped off and a lever I can not tell what it does but when I engauge the lever I do not hear a pump load up or any differance in the way the tractor is idling. Help!!
PatM
11-13-2001 06:20:35
 Re: '48 M need info in reply to Busch, 11-12-2001 15:43:57
That pump may be low or out of oil. There's a cap in front of the battery and above the pipes on the side, on the right I think, that should have a dipstick attached.
Haas
11-12-2001 16:22:31
The wheel on the side must be the belt pulley. Used with a flat belt to run equipment like feed grinders, blowers, threshers and so on. There were two kinds and several different sizes. They came in steel (not common) and paper. Yes, paper. They are made from compressed paper and resin mounted on a cast steel base. If it it still in good condition, and not lobsided, etc., do take it off and store in inside, not on a damp floor. If it gets wet, it may swell up and be ruined. There is a company that rebuilds the paper wheels, but it costs $150 or more. From your description, it sounds like you have a hyrdaulic Lift All (or commonly called a belly pump). That is a hydraulic pump and reservoir that is mounted up in the belly of the tractor under the main drive shaft just behind the clutch. If it is working, you should notice the tractor engine load up when you pull back all the way the activating rod located on the left side near the light bar. The pump only works when the clutch is engaged, so if you have been pulling the rod with the clutch depressed, nothing will happen. Put the transmission in neutral and release the clutch before pulling the rod. The oil level in the Lift all reservoir is checked at a cap that is just infront of the belt pulley on top of the clutch housing. The capped off pipe fittings are the pressure connections for the hydraulics, one on the right and two on the left. Hope this helps.
Busch
11-12-2001 17:47:30
 Re: Re: '48 M need info in reply to Haas, 11-12-2001 16:22:31
thanks mine has to be paper and by the end of the night it will be in the basement.
Dick Davis
11-13-2001 02:19:43
 Re: Re: Re: '48 M need info in reply to Busch, 11-12-2001 17:47:30
Attic would be better storage for a belt pulley than basement.
