Super C PTO
J3nut
10-26-2001 15:26:39
I am rebuilding my Super C and am currently replacing seals in the PTO. When I pulled the PTO unit, I noticed the 49 tooth gear on the PTO shaft is missing most of one tooth.
I have mowed (brush hog) with the tractor recently and did not notice any noises or problems.
My question is…should I replace the gear or keep using it? I plan to mow with it but that is the hardest use the PTO will see.
Thanks for your help.
Mark
Ralph
10-27-2001 16:58:29
 Re: Super C PTO in reply to J3nut, 10-26-2001 15:26:39
J3nut: I'll suggest you use a long handle magnet to fish that loose tooth out of the bottom of there. Some times a loose tooth can be picked up by oil and get lodged in a very bad place.. and much more damage will result. R.
DaveT
10-27-2001 07:17:40
If you can located one easily, I would replace it. Sooner or later more teeth will break out until you have junk. Check your IH dealer, some of these gears are cheaper than you might expect...
J.D. Humm
10-27-2001 13:17:29
 Re: Re: Super C PTO in reply to DaveT, 10-27-2001 07:17:40
I would replace it also. Those teeth could do a lot of damage to the rest of the rear end if one got in the wrong place.
