W 30
shayne
10-14-2001 13:51:35
I have come accross a McCormic Dearing W 30 that I might get for the price of towing it away.The tin is all there and in good shape,however the engine is stuck.Would someone be able to advise me on the availability and epence of parts for this tractor.Were they common?What years were they produced?
Thanks Shayne
Milton Fox
10-15-2001 15:10:49
 Re: W 30 in reply to shayne, 10-14-2001 13:51:35
Shayne; ----- -- 15 / Oct. / 2001 The International McCormick Deering "W-30" was manufactured from 1932 to 1940, there were
32,540 made.
The International McCormick Deering Farmall "F-30" was Manufactured from 1931 to 1939, there was 29,525 made.
Good luck with your "W-30" / Cheers / Milton
F-Dean
10-14-2001 20:04:49
Rice equipment has parts. Most are interchangeable with an F-30.
Haas
10-14-2001 15:30:53
If you can get if for hauling it away, I would not pass it up.
The Red
10-14-2001 14:13:27
About 32,500 W30s of various configurations were built. Another 30,000 or so of F30s were built. They both share a lot of the same engine parts. Engine parts can be had but not real easy. Tractor parts unique to the W30 would be pretty scare I would think. If you got the room and time and $$$$, that would be an interesting restoration!
Andrew from Aust.
10-16-2001 00:06:49
 Re: Re: W 30 in reply to The Red, 10-14-2001 14:13:27
Go for it! They are a nice old tractor. If you can get it cheaply you can safely justify your costs. If you are patient you will be surprised where parts will turn up. My mate had started restoring a W40 which had excessive ring gap (about 90 thou!!)Anyway a new set of pistons/rings and sleeves was advertised about a month later which he obtained for three hundred dollars (Aust. dollars, about half yours!)
Good luck!
shayne
10-20-2001 04:46:24
 Re: Re: Re: W 30 in reply to Andrew from Aust., 10-16-2001 00:06:49
Thanks for all the help boys,I'll look further into this tractor.As for justifing my costs,well I'll try to explain that to my wife.
