NEED TO KNOW YEAR SIZE OF MY TRACTOR
LOUIS
10-09-2001 06:51:30
I HAVE A SUPER A FARMALL McCORMICK HI TRACTOR AND HOW DO I FIND OUT HOW OLD IT IS AND WHAT SIZE MOTOR IT HAS?
WHERE IS THE SERIAL # LOCATED? I KNOW IT'S ANTIQUE BUT I NEED MORE INFO?
ANY INFO WOULD BE GREATLY APPRECIATED!
THANK YOU LOUIS
Phil Auten (Tx
10-09-2001 09:01:14
 Re: NEED TO KNOW YEAR SIZE OF MY TRACTOR in reply to LOUIS, 10-09-2001 06:51:30
Louis,
The Super A used the C-113 engine, same as the A, B , C and Super C (early) tractors. 113 Cu. In. displacement, 1,400 RPM governed max speed and 17.35 drawbar HP, 19.06 PTO/Belt HP. Compression ratio is 6.0:1, 11 gal. fuel tank and it weighs 2,385 lbs without wheel weights or fluid in the tires.
Courtesy of Guy Fay's Farmall data book,
Phil
Dave BN
10-09-2001 07:22:47
Louis; Welcome to Y.T. Repost if you need more help. Lots of experts here who are glad to share info with. Andy's correct as to years Super A was built. I think it's about 16hp. Repost with serial number and we'll get the exact details. Dave.
Louis
10-09-2001 08:25:00
 Re: Re: NEED TO KNOW YEAR SIZE OF MY TRACTOR in reply to Dave BN, 10-09-2001 07:22:47
Thanks Dave,
The serial # is FAA 169902
If you know the year or size of motor please remit.
Louis
Jim Becker
10-09-2001 09:03:18
 Re: Re: Re: NEED TO KNOW YEAR SIZE OF MY TRACTOR in reply to Louis, 10-09-2001 08:25:00
That serial number is for a '46 A, not a Super A. The major difference is that the A did not come with a hydraulic system but most Super As did. The A (gasoline version) had a bely horsepower rating of 19.
Louis
10-09-2001 08:22:56
Thanks Dave,
Louis
Andy Martin
10-09-2001 07:05:54
Serial number plate is on the right side of the left seat support, under the seat.
Look at thte links at left to determine the age from the serial number. It will be from the late '40's to the early '50's for a Super A.
LOUIS
10-09-2001 08:04:02
 Re: Re: NEED TO KNOW YEAR SIZE OF MY TRACTOR in reply to Andy Martin, 10-09-2001 07:05:54
THANK YOU VERY MUCH. THE NUMBER SEEMS TO START WITH FAA 169902
IF YOU KNOW THE AGE I'D APPRECIATE IT. DO YOU KNOW THE SIZE OF MOTOR?
THANK YOU LOUIS
ALABAMA
10-09-2001 09:06:33
 Re: Re: Re: NEED TO KNOW YEAR SIZE OF MY TRACTOR in reply to LOUIS, 10-09-2001 08:04:02
I noticed your serial numbers don't match for a Super A (links to left). I can't recall but the you should be able to tell the year from the letter code. Some one else with better references should be able to look it up. It may be a 1947 A that some one modified and put a Super A Sticker on. As far as the tire size goes, I'd have to check when I get home.
ALABAMA
10-09-2001 09:06:06
