PARTS FOR EXHAUST LIFT ON FARMALL A
PETE
09-28-2001 14:54:54
INSIDE THE EXHAUST LIFT CANNISTER THERE IS SOME TYPE OF GASKET THAT FLOATS UP AND DOWN WHEN PRESSURE IS APPLIED. IS THIS GASKET AN I.H. SHELVE ITEM OR CAN SOMEONE TELL ME HOW TO MAKE A NEW ONE
gene b
09-29-2001 02:57:46
 Re: PARTS FOR EXHAUST LIFT ON FARMALL A in reply to PETE , 09-28-2001 14:54:54
last time I checked with dealer price was 42 I make mine out of leather use a big hose clamp aand oil to form it around the piston so far havent needed the expansion spring for it to work made a hone with a piece of wood and some 9in sanding discs for cleaaning the bore of the cycl use plenty of oil when done to keep the leather moist and pliabable use three of these and have parts quite a device
Eddie Petty
09-28-2001 17:19:22
Pete, If it's the control valve you're speaking of (right hand side above/behind the oil filter)the IH p/n is 15 217 E. If you're talking the actual Lift-All cylinder, the piston ring is p/n 15 184 E and the end seals are p/n 15 186 E and 15 185 E.
Try an IH dealer (doubtfull). I made all of mine from reinforced rubber sheet.
HTH's Ed
