Help with my Super M. Please.
Mark
09-20-2001 10:41:22
My Super M smokes kind'a bad. I took a compression test on the cylinders, and all pumped up quick, and held, 90 lbs. of presure? I have discovered a leak/crack in the intake manifold. It is also spitting oil out around the spark plugs(1 & 2) and the manifolds? The engines starts right up easily. Any ideas?
Mark
09-21-2001 04:42:07
 Re: Re: Help with my Super M. Please. in reply to Kendall, 09-20-2001 13:39:13
Thanks Kendall. Thats what I am thinking, also. Are valve grinding gasket sets available? How about valves, guides, springs, etc.? Any help would be appreciated. Mark
Mark
09-21-2001 15:56:16
 Re: Re: Re: Re: Help with my Super M. Please. in reply to Kendall, 09-21-2001 08:14:05
Thanks for the info. Does anyone know what the valve grinding gasket set number, with maker(McCord, or?) would be. I have a local parts house that will order for me if he has a number. Thanks again.
Dale13
09-21-2001 05:20:02
 Re: Re: Re: Help with my Super M. Please. in reply to Mark, 09-21-2001 04:42:07
Quality Farm,Central Tractor or even a good machine shop all have what you want.
