H Farmall hydraulic pump leaks
Peter Hatlestad
09-19-2001 05:49:52
I am looking at buying an H farmall that looks to be a good tractor except the hydraulic pump leaks quite a bit.
What do you think it will cost to go through that pump? And how much is an H farmall worth these days in SD. It has good matching tires and the tin is straight and it runs nice except for that pump leaking.
Ray
09-19-2001 09:37:21
 Re: H Farmall hydraulic pump leaks in reply to Peter Hatlestad, 09-19-2001 05:49:52
Peter:
I bought a 1950 Farmall H a few months ago in Iowa for $800. It was in great shape, good tires, tin straight, converted to 12 volts and it came with a trip bucket loader. I would not trade it for anything right now. Price depends on how bad you want or need it. I talked the guy down from $1000 after I drove it and found out 5th gear jumped out when driving it down the road. Which is common after years of abuse. Good luck...
Ray..
The Red
09-19-2001 06:54:25
Peter the two primary areas of leaking on the liftall are the countershaft seal and the reservoir gasket. For now I would recommend you remove the counter driveshaft, from the transmission to the liftall, until you have time to remove it if you end out buying it.
To remove the countershaft, remove the lower inspection plate. Pull out the two large cotter pins and slide the collars towards the center of the countershaft. The shaft will then come out.
Richard C
09-19-2001 10:55:51
 Re: Re: H Farmall hydraulic pump leaks in reply to The Red, 09-19-2001 06:54:25
Hey Red whats the purpose of removing the shaft?
Is it just so you don't run the pump on low oil???? Just wondering because my pump leaks too
The Red
09-19-2001 12:05:28
 Re: Re: Re: H Farmall hydraulic pump leaks in reply to Richard C, 09-19-2001 10:55:51
Yep you could run that out of oil and do damage to the pump.
Chums5
09-19-2001 06:12:27
Pete....the pump is pretty basic as hyd. pumps go..mainly gaskets if the gears are OK..... ..don't know about SD but in Wisc. the one you discribe should go for 7 to 1000. here...seen on go for 1400 at auction last week with fair tin but new rubber all round and fresh paint....help this is some help....Good Luck...
