Super M running poorly
Dale (MI)
09-17-2001 13:55:27
My Super M is running on only two cylinders now. I just put two new plugs in cylinders 2 and 3 but it made no difference. If I pull the wires on 1 and 4, it dies. The plugs and wires seem good. I also noticed that oil started leaking out of the exhaust manifold for those two cylinders. Any suggestions?
Farmer-Gene
09-18-2001 03:57:08
 Re: Super M running poorly in reply to Dale (MI), 09-17-2001 13:55:27
Are you sure you have the firing order correct or could be bad dist. cap.
TomH
09-17-2001 17:01:01
I'd look for ignition problems first. Suspect the distributor cap or wires, pull the plug and watch to see if it sparks. If that's not it check the compression in 2 & 3, could be a head gasket.
Charlie
09-17-2001 15:02:42
Oil running out of the manifold sounds like you should pull of the valve cover and have a look. Could be a bent push rod and the valve(s) are not closing. You may also want to do a compression test to see if all the cylinders are the same. In addition, anything running out of the manifold suggests a leaky manifold. If there is a leak in the intake side it can cause the tractor to miss - the two that are missing are together and could be affected by the same leak.
Dale (MI)
09-17-2001 16:44:02
 Re: Re: Super M running poorly in reply to Charlie, 09-17-2001 15:02:42
It is the exhaust side. It sounds like a lawn mower. I'll see if I can get the valve cover off.
The Red
09-17-2001 13:58:54
My initial observation would be that you have bad plugs or plug wires on 2 and 3. Had it been running on 4 and this just happened or what? What spark plug are you using?
Dale (MI)
09-17-2001 16:40:23
 Re: Re: Super M running poorly in reply to The Red, 09-17-2001 13:58:54
I was running Champion 502 (D21). I swapped plug wires between a good and bad cyclinder and it did not matter. I went to a nearby AGCO dealer (CASE/IH is further away) and they recommended a hotter ACDelco C86. Those showed a better spark when I have out of the engine but made no difference when I put them in. It still dies if I pull off the 1 and 4 wires. The other two make no difference, i.e. are not firing as far as I can tell.
