Rockford clutch
doug vose
09-12-2001 18:38:30
this is a probaly a stupid question, but, what is a rockford clutch. is it just a fancy name or what. I just wanted to know because my 300 has one(they probaly all do) and in case somebody asks me. thanks
Tyler (MD)
09-13-2001 16:36:00
 Re: rockford clutch in reply to doug vose, 09-12-2001 18:38:30
third party image
My Super A has a "Rockford" clutch. The other option was the "Auburn" clutch. Both are shaped different.
Tyman
Tom
09-13-2001 13:09:01
The best I can tell is that they were just another supplier of IH parts. They otherwise were virtually identical in performance and specs. I can't explain why IH decided to point it out in the serial number sufffix, maybe one of the former IH workers can explain.
Jim Becker
09-16-2001 09:33:51
 Re: Re: rockford clutch in reply to Tom, 09-13-2001 13:09:01
I am under the impression that the idea was so you would know which type was in the tractor before tearing it apart. That way you could be sure the right parts were on hand. In practice, I don't think it helped much for several reasons: 1) When you tear it apart, you still might find the other clutch (even from the factory), 2) If you were replacing the whole clutch, either one would replace the other, 3) If you were just changing the disc, they would interchange on many models anyway.
the tractor vet
09-12-2001 19:06:26
Most of them are but every once in a while you will run into and overcenter clutch and they are the hand clutch .
