Farmall H running rough
glen emery
09-06-2001 13:27:32
I have a '46 Farmall H. It misses and runs rough. I've had the Magneto overhauled, and am getting good spark, I've put in a carburetor kit, new plugs, new copper core plug wires, and adjusted the valves. It's not burning any oil. It starts good. When idling it pops and misses, when you rev it up, it pops, misses and shakes. With a load on it, it evens out but doesn't have much power. Anybody got any suggestions? What do I try next?
Jim
09-07-2001 09:01:50
 Re: Farmall H running rough in reply to glen emery, 09-06-2001 13:27:32
As Mr. Soldan made the point of sucking air in the manifold, if you pull the choke out does it smooth out ? This is the first step before using the gas, I think.
cornfused
09-06-2001 17:44:24
At risk of insulting you, check the firing order. When changing wires it is easy to get one wrong.
glen emery
09-06-2001 23:22:09
 Re: Re: Farmall H running rough in reply to cornfused, 09-06-2001 17:44:24
firing order is right, i did think of that.
michael Soldan
09-06-2001 16:03:22
Glen, two things come to mind to check out for the way you describe your H's behavior. The carb could be putting too much fuel into the system on the low idle..this would explain why it seems fine under load at higher speed. The second thing is to check and make sure the manifold isn't sucking in air. This is easy to test with an acetylene torch or a propane torch...let the tractor run at the speed it seems to sputter and miss at..turn the propane or acetylene on and run the nozzle of the torch around your manifold...if it smooths out when you get close with the gas then its sucking air and you have a bad gasket or a crack in your manifold..which will cause the symptoms you have described....I have an H that has done the same thing and even though the carb has been rebuilt it needs to be looked at again for low speed idle...good luck from Mike in Exeter Ontario.
glen emery
09-06-2001 23:26:50
 Re: Re: Farmall H running rough in reply to michael Soldan, 09-06-2001 16:03:22
thanks, I'll try checking the manifold. I hadn't thought of that. One other person said I might be getting too much gas. I've checked the float, and replaced the needle and seat, when I rebuilt the carb.
Redtractorman
09-06-2001 13:31:58
Try loosening the bolts on the mag and turning one way or the other it may be out of time a little,when you took mag apart did you get the little plastic gear timed right.
glen emery
09-06-2001 23:24:35
 Re: Re: Farmall H running rough in reply to Redtractorman, 09-06-2001 13:31:58
yep, mag is timed right. I had to take it to a mag shop to have that set. advancing and retarding the timing makes some difference but not enough.
