Famall 200 same as Super C?
Paul
09-05-2001 06:19:10
Found an old famall that you can still make out the out line of International 200 on the side. I don't think there is any difference between the 200 and the Super C...can anyone confirm or deny?
Thanks!
RayP(MI)
09-05-2001 15:16:14
 Re: Famall 200 same as Super C? in reply to Paul, 09-05-2001 06:19:10
I have one ( a 200 that is,) and as far as I can tell, they're pretty much the same. Cosmetic changes on hood and radiator and a metal name plate are the main differences that I can discern.
Same
09-05-2001 06:27:10
just minor changes. Mostly style changes to grill etc.. they just could't leave a perfect tractor alone. They improved it slightly. grin R.
J.D. Humm
09-05-2001 16:53:47
 Re: Re: Famall 200 same as Super C? in reply to Same, 09-05-2001 06:27:10
Basically the same tractor, Paul. The 200 had different sheet metal and turned 200 more engine rpm plus maybe had one or two more hp due to the higher speed.
Jimbub
09-06-2001 15:26:00
 Re: Re: Re: Famall 200 same as Super C? in reply to J.D. Humm, 09-05-2001 16:53:47
J.D. MY 53 super C turns 1650 rpm and book by Pripps shows the 200 also at 1650. Did it change After the start of production or is my book inacurate!
