Nuisance gas leak on Farmall B
Author |
Dave T
08-29-2001 21:45:18
I finally got around to fixing that nuisance drip from the gas tank. Right where the tank bracket is fastened to the tank. I replaced the tank from a parts tractor, figured I had it, but darn it, this one leaks in the same place too. I'm thinking of trying the product that you line tank innards with, but I don't have the product info, and where I can get it. If anyone has this info, please post it....thanx in advance,,,Dave
redhead
08-30-2001 08:17:07
Re: Nuisance gas leak on Farmall B in reply to Dave T, 08-29-2001 21:45:18
NAPA sells a sealer called REDKOTE. It's good stuff and easy to use. Sounds like your B is leaking in the same spot my A was. There was crack where the baffle is spot welded to the inside of the tank. This spot weld is right under the mounting bracket. I ground the bracket back with a die grinder to expose the crack then brazed up the crack and put a new metal piece on the bracket. CAUTION: wash out the tank with hot/soapy water and let it dry in the sun for a few days with the cap and bowl off. Also, fill it with water before you grind and braze. Good luck.
BTD
08-30-2001 10:00:15
Re: Re: Nuisance gas leak on Farmall B in reply to redhead, 08-30-2001 08:17:07
I used RedKote on my M's gas tank. It works great, but it dribble out the bottom hole for 24 hours or so. I was told to let it do that or as the stuff thinned on the sides and top it would build a think pool on the bottom. Make sure you have wood or plastic under the tank to catch any drippings. I found that cardboard don't cut it and now I have a nice red disk on my shop floor to be hammered off. But the tank is looks great! Soon to be red inside and out! -BTD
Haas
08-30-2001 06:42:41
I got mine sealer From Eastwood. Used it on my C about 6 months ago. Works great. Does not tell you in the ad, but you also have to buy a jug of muratic acid and a can of acetone at a paint store or building supply. Brings the total cost with shipping to around $60. Be sure to follow the directions to the letter!
Haas with link I hope works
08-30-2001 06:48:53
Re: Re: Nuisance gas leak on Farmall B in reply to Haas, 08-30-2001 06:42:41
Apparently you can't go directly to the item without going through the Eastwood Home page. Search on Tank Sealer once you get to Eastwood.
Justin in Pa
08-30-2001 05:16:48
If no luck anywhere else, try a motorcycle shop. I got the Kreem at a Honda store here in Pa. It consists of three bottles. Follow the directions carefully and it will work great.
Red Dave
08-30-2001 05:07:45
I had the same problem on a tractor and used a coating product to seal it. Works fine, no problems for about 5 or so years now. Follow the directions faithfully. Use the cleaner that your sealer calls for to get it ready to coat. I put several coats in mine. It takes a little time, but it's worth it. I got mine from a supply shop in California that advertised in Red Power magazine, I don't remember the name of it.
big fred
08-29-2001 21:52:59
J.C. Whitney calls theirs "Kreem", the Eastwood Company just calls it "gas tank sealer". I don't know for sure if NAPA carries the same kind of product, but it's worth asking them about it. Just ask for gas tank sealer or "sloshing sealer". If they carry it, they should be able to identify it by that name.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Talk of the Town: Removin Broken Bolts - by Staff. Another great discussion from the Tool Talk Discussion Forum. The discussion started out with the following post: " How would I remove a bolt thats broken off in a piece of metal and I want to save the treads in the metal and then put in a new bolt. "
... [Read Article]
Latest Ad:
for sale New mamifold for IH 504 tractor 100 plus shipping
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
