M charges
not!
John Blanc
08-21-2001 03:52:21
Generator checks good, ammeter shows 10+ charge (increases with higher RPM), 4 position switch, positive ground, batteries ( have switched three) charge on charger but not on tractor! Battery terminals have been wire brushed. What next? thanks
The Red
08-21-2001 05:35:28
 Re: M charges - not! in reply to John Blanc, 08-21-2001 03:52:21
Remove the cover on the voltage regulator and make sure the points are opening while the engine is shutting down. If they don't open, your battery will run down in a few hours.
John Blanc
08-22-2001 04:11:40
 Re: Re: M charges - not! in reply to The Red, 08-21-2001 05:35:28
Thanks, I'll give it a try.
