460 hydraulics
mike
08-16-2001 19:11:31
my lift is slow with 1000lb bushhog. also need to rev engine to about 1500 just to move it. is the pump weak? i changed fluid and filter, nbut no help. thanks mike
mike
08-17-2001 19:19:04
 Re: 460 hydraulics in reply to mike, 08-16-2001 19:11:31
probably is the pump. are there 2 pumps and is it rebuildable ? is it hard to change? thanksmike
KURT
08-17-2001 13:46:13
FIrst thing I would do is a pressure check on the hydraulics, and go from there.
kev@ia
08-17-2001 04:05:36
Been there, just getting that fixxed. Either your preasure relief is wore out, your pump is failing or you have too small a hyd cylinder on your mower. The bad part of the pump wearing is the gear that drives it and the piggie backed powersteering pump moves out of engaguement and the gear starts to wear funny, it also might fail and then neither pump will work. kev
