The lesson I learned on splitting my H
Author |
Zonie
08-07-2001 21:02:47
This last weekend I finally decided to go ahead and split the tractor. I've known I had to do it because I have to pull the crank to get it turned. After removing the frame rails and bolster I hooked up my cherry picker and removed the 2 upper clutch housing bolts. Then I climbed underneath and dropped the lift all and clutch. I found out that I didn't need to remove the clutch or lift all to split the tractor. The way I figure it I wasted a few hours removing stuff I didn't need to. I've been wanting to replace the seals in the front of the transmission and the liftall and I guess now's the time to do it so I won't feel too dumb for doing unnecessary work. Maybe I should have read my I&T manual, huh? Oh well we live and we learn.
Charlie
08-08-2001 14:30:33
Re: The lesson I learned on splitting my H in reply to Zonie, 08-07-2001 21:02:47
I think you'll find it easier to put the engine back on if the clutch is removed. I put the engine back in my M one time with the clutch still in the tractor and ended up warping the clutch plate - had to replace it.
doug
08-08-2001 04:17:31
Well, just mark it up as educational,we all learn more if we go the long route,eh? By the way... could a guy remove each rail, one at a time to clean them up and paint inside them? what do you think? I've got the big casting off of the front of the M and the tractor is on a stand, ( the engine stays on)I'm thinking about putting blocks under the transmission before I do this and I've been putting it off for lack of knowledge...
Zonie
08-08-2001 20:39:00
Re: Re: The lesson I learned on splitting my H in reply to doug, 08-08-2001 04:17:31
A few months ago I removed the side rails on my H one at a time for sand blasting and painting. I'm sure now that you could remove both at the same time if you support the tractor under the flywheel housing. I use blocks of wood, 6"x8"x36" and a 2x4 to support mine and make sure the wheels are blocked.
Andy Martin
08-08-2001 10:50:01
As I understand what you are saying, you only have to remove the front two motor mounts to remove the side rails. The steering/radiator support casting is removed? If so, you should be able to remove both rails as the engine to clutch housing bolts will certainly support the engine.
Doug
08-11-2001 22:31:13
Re: Re: Re: The lesson I learned on splitting my H in reply to Andy Martin, 08-08-2001 10:50:01
Zonie and Andy,Thanks so much! both rails are off and oil pan bolts removed(a few at a time,cleaned and reinstalled) this will make it look good when I get it painted, soon my Dad hopes... he refuses to help...
Doug
08-09-2001 04:40:11
Yes, I removed the front casting to clean it up for painting,it comes off easily with an engine crane,enough dirt in there to grow potatoes!Just was not sure about taking the rails off, looks cruddy in there too.I might get to that today,thank you guys!
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
The Collection of a Lifetime - by Sherry Schaefer. The larest gathering of orphan tractors ever assembled by one collector will be auctioned off on May 15 in Rock Island, IL. Ed Spiess was a well known tractor buff who spent most of his time dreaming of rare and unknown tractors. His background as an agricultural engineer sparked his interest in the unique attributes of the models built from 1939-1959.
... [Read Article]
Latest Ad:
Need a clutch shaft for a 46 Massey Harris 101 Jr., F162 Continental engine. About 18.25 inches long, to fit 1-1/8x 10 spline clutch disk. Bare shaft without sprocket or bearing is OK.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
