Super C Smokes at Start-up
Farmall Pete
08-06-2001 13:26:22
I've had the tractor for about a year and just getting started on fixing her up. Engine runs strong other than some carb problems. Just recentley when I first fire her up, a lot of blue smoke billows out until she is warm. I can deal with white or black smoke, but blue? Am I looking at a valve job or a complete rebuild? How can I tell if I need just sleeves and pistons or replace all the bearings, grind crankshaft, etc?
The Red
08-06-2001 14:25:47
 Re: Super C Smokes at Start-up in reply to Farmall Pete, 08-06-2001 13:26:22
More than likely the valve stem guides are worn. They usually start leaking before the rings go. However if it is smoking for a period of time, I would suspect the oil scraper ring on each piston is getting worn.
I'll let the C experts answer your other questions.
