Can I put a loader on A
Hunter
08-05-2001 12:53:13
Can I put a loader on a farmall A. Does it have a 3-point hitch?
Red Dave
08-06-2001 09:37:01
 Re: can I put a loader on A in reply to Hunter, 08-05-2001 12:53:13
The loaders I have seen on A's are manure loaders. They work OK at what they were made for. Usually run hydraulics off the PTO for lift and use a trip bucket. Like oldrediron says though, it's not a bulldozer.
A's did not come with a 3 point hitch. I have heard of some homebrew designs, but again you have to overcome the lack of hydraulics.
oldrediron
08-05-2001 18:39:28
I have a Farmall A with a Freeman loader. I use it for LIGHT work, it is NO bulldozer. The front end is really built to light for the loader. These tractors were built for cultivating and that's about it. You can really start tearing the tractor up quick if you are not carefull!! BEEN THERE DONE THAT. But an A with a loader is very handy to have around.
Red
08-05-2001 13:18:11
I take it, since you asked about the 3-point hitch, you don't have an A yet. An A I don't believe had a factory three point hitch. Some A's might have a 3 point hitch that has been added on. An A is pretty small, just a little bigger than a Cub. I don't know what you are planning to use this A for but sounds a little small to me for a loader possibility. I have never run a loader on anything smaller than an H. A loader seems to work better on the M than the H and I believe it does becuase of the bigger sized tractor. An A is really a yard and garden sized tractor even though some people go to the field with them. They just aren't big enough to really go out and get alot done on. Alot of people like the A for gardens and bigger yards and they can put it in a little fart of a shed becuase it don't take up much space. Tell us what you are planning on using this A and loader for. It is hard to say what you need when we don't know what it is going to be doing.
