???Tractor Radio???
Denny Resop
08-01-2001 22:06:44
In the scrap bin at work I dug out a radio built into a metal box with a hinged front cover,it's mounted on an aluminum plate,the plate has a round opening on the bottom that a pipe can be inserted for mounting purposes.The radio brand name is Automatic Radio.I was told that this is an aftermarket fender mounted tractor radio,is this true.Any info please. Thank you,Denny Resop
Leonard W. Molberg
08-01-2001 22:49:18
 Re: ???Tractor Radio??? in reply to Denny Resop, 08-01-2001 22:06:44
I've seen them advertised often in the past, but can't remember where.
I'm sure that is what you have, however.
I wish I had one for my open tractors. It would have to be pretty loud, however, to keep track of baseball and football games. It would also need to have the FM band for the classical music station I like to listen to. I'm an unconventional farmer that way.
Leonard
Leonard
Brent
08-02-2001 04:21:01
 Re: Re: ???Tractor Radio??? in reply to Leonard W. Molberg, 08-01-2001 22:49:18
You can still buy these at CT or TSC and probably even at the local implement dealer. I have the holes on my 560 hood right in front of the steering wheel where my uncle had his mounted for many years. They haad a pretty good volume on them as they had to combat the tractor engine so you could hear them.
Phil auten (Tx)
08-02-2001 07:23:11
 Re: Re: Re: ???Tractor Radio??? in reply to Brent, 08-02-2001 04:21:01
Yup. Saw some at the TSC store in Temple just the other day. My thought was that the volume would have to be very loud to be heard over the tractor.
Phil
Denny Frisk
08-02-2001 05:51:02
Spent A LOT of time listening to WLS in Chicago to one of those Automatic radios. I got a "TENNA" for my birthday when I was 14 to go on My H and Super H. The radio just finally died. I'm enlarging the enclosure now at home to put an AM/FM/cassette & a couple speakers out of a car in it. Dad tried mounting them on the axle carrier of M's & mounting them in frt of the steering wheel. Mine's going in frt of the steering wheel! They pretty much had to be played WIDE OPEN to be heard over the engine. You could actually hear the radio better from a half mile away than You could hear the tractor! Problem with the old Automatics was the enclosure was about a foot tall. I couldn't see over it when it was in frt of the steering wheel, hense, the fender or axle carrier mount.
David A
08-02-2001 09:11:09
 Re: Re: Re: Re: ???Tractor Radio??? in reply to Denny Frisk, 08-02-2001 05:51:02
....hear it a half mile away.... you got that right! My next door neighbor farmer used to cultivate all night long and I could sure hear his tractor radio.
Denny Frisk
08-02-2001 05:48:59
