'53 Super H Carbutor Rebuild
Hank
08-01-2001 12:34:48
I ordered an after market rebuild kit for the SH and when it came it said it was for an M (I called company and they said it was the same as SH) I now have problem with black smoke and fowling plugs. Where can I get specs on rebuild and is the M kit same as the 53 carb rebuild kit?
Bama Binder
08-01-2001 13:46:57
 Re: '53 Super H Carbutor Rebuild in reply to Hank, 08-01-2001 12:34:48
I rebuilt my SH carb last year and I remember the "basic" kit that was just the throttle shaft, needle valve, and gaskets was for the M and Super H. I think Denny is right in that the SH carb may have smaller jets or the same jets just with the main jet set leaner, but my kit didn't have those so it didn't matter.
I have only rebuilt 2 carb with basic kits, but I can't imagine what kind of abuse it would require for a carb to need a more complete kit unless you happen to loose a part...
Anyway, you probably have the right kit.
Denny Frisk
08-01-2001 13:31:39
The Carb castings are the same, the 1-1/4" updraft, but the settings, jets & stuff are different. Sounds like You should lean it out a bit.
Denny Frisk
08-01-2001 13:29:37
