My Farmall 100
larry rothe
07-30-2001 16:08:05
I just recently purchased a Farmall 100, it has all the attachments and rear tires are in excellent shape, does not run, and clutch is stuck, is it worth anything?
John N
07-31-2001 10:33:12
 Re: My Farmall 100 in reply to larry rothe, 07-30-2001 16:08:05
The clutch on my Super A was also stuck. After fishing out a mouse nest, my mechanic was able to reach in through the inspection opening and tap the clutch, and got it to let loose. It wasn't major at all, and the tractor didn't have to be split.
If the engine is loose, the tractor has reasonable value.
Haas
07-31-2001 06:06:44
Yes, it is worth something. Depends on what attachments you got. If the engine is not stuck, you can fix the clutch and probably have it running pretty easily.
