Re: Old Rusty H progress?
The Red
07-27-2001 07:28:28
Nothing at the moment Ryan. I haven't decided whether to part it or find another engine. It is snoozing under a tarp. I might drain the 90W this weekend to see how bad it looks.
Ryan - IN
07-27-2001 08:25:43
 Re: Re: Old Rusty H progress? in reply to The Red, 07-27-2001 07:28:28
Last I knew, you had gotten the pistons sleeves & pistons out, is the block bad?
The Red. YEP
07-27-2001 08:39:34
 Re: Re: Re: Old Rusty H progress? in reply to Ryan - IN, 07-27-2001 08:25:43
Large dent and major 1" horizontal crack in #1 cylinder wall about 4 inches down. It is very obvious from the impression that a rod broke and did major damage. Someone simply stuck back in sleeves and let it leak coolant in the oil. The crack is unfortunately on the pushrod chamber side of the engine.
Scott S.
07-27-2001 10:45:50
 Re: Re: Re: Re: Old Rusty H progress? in reply to The Red. YEP, 07-27-2001 08:39:34
Hey Red, I have a magged engine block out of a tractor just like yours. I will probably not need it. I will give you a good price on it. It has been cleaned, checked for cracks and what ever. The head bolts are still in the block.
Let me know if you can use it.
Scott
