IHC Gray paint codes before 36'
Patrick McChris
07-23-2001 20:58:36
What are some paint codes for IHC gray for tractors before 36'. Some different codes that can be readily found would be nice. Thank You
Kent
07-24-2001 18:17:48
 Re: IHC Gray paint codes before 36' in reply to Patrick McChristy, 07-23-2001 20:58:36
Patrick, VanSickle paints, available at hardware and farm stores, says mix 3 qts of their #463 Gloss Black with 1 qt of #462 Gloss White. I would recommend using a hardner. I don't have a paint booth nor the talent to use the expensive automotive paints and have been satisfied with the Vansickle paints (about $20/gal).
Good Luck
K-Mo
blarson
07-24-2001 04:40:01
I just painted a '35 f-12 and used PPG Omni AE #32565 I believe the Dupont # is 27625
