IH 574 What is one worth?
Mike Elton
07-23-2001 13:16:12
I found one in south dakota for sale and was wandering its value. The clutch is out and hydralics are weak maybe or the filter is dirty.It is wide front and is gas, tires are ok. A school owns it and they want bids, what do you think? Thanks ahead of time.
Ray
07-23-2001 20:44:26
 Re: IH 574 What is one worth? in reply to Mike Elton, 07-23-2001 13:16:12
Yup parts are pretty spendy. Clutch assy could run 800.00, don't know the price of a hyd. pump. Run it under load for 30 min to and see if the oil guage reads one third from the left at 100 rpm over idle - if oil pressure is lower you may want to keep looking - overhaul price for short block and head is about 4500.00 just for parts.
Big Jim
07-23-2001 14:34:24
Mike,
I go to a lot of auctions and the 574's still bring pretty good money. Generally at least $5,000 to $6,000. Often, I will see them sell with an all hydraulic loader and bring $9-10,000. They are older, but still new enough to have modern features like power steering, indepedent PTO, factory 3 pt., so they hold their value pretty good. If the clutch and hyraulics are potential problems, I would contact your Case-IH dealer and see how much a new hydraulic pump and clutch would cost. You can then adjust your bid accordingly. Parts can be plenty expensive, so assume the hydraulic pump is bad, rather than just a dirty filter. You can really end up on the short end if you pay too much.
Will
07-25-2001 07:04:46
 Re: Re: IH 574 What is one worth? in reply to Big Jim, 07-23-2001 14:34:24
We had one and finally sold it about three years ago. The original hydraulic pump was a problem. Apparently there was a factory change and you have to install an adapter with a new pump and the thing is a headache... other than that it was a great tractor- we literally ran it until it fell apart. With a rusted out hood, leaking coolant and two bad tires, it sold for $1,900
