Re: Way off topic, but still interesting.
big fred
07-18-2001 14:42:24
Matt, last fall I bought a '50 Ford 2-ton flatbed to haul tractors. It was running when I bought it, and drove it 75 miles home before really going over it thoroughly. What I discovered made me thankful I made it home. The insulation on the wiring was all cracked and shorting out, there was a slow leak in the gas line, and the brakes leaked (I knew about the brakes when I drove it). The first thing I would do if I was you is check out the wiring and make sure a mouse hasn't made the truck a firetrap, then put in a gallon of gas and check for leaks, then change the oil, shoot some oil in the cylinders and crank it a few turns with plugs out, check the radiator, then try starting it. If it was a Ford, I could point you towards a few good websites, but don't know with a Chevy. Best bet is enter "antique chevy truck" in a search engine and go from there. Good luck!
