10-20 Serial # location?
Cory Vellinga
07-17-2001 10:40:43
I have a nice 10-20 that runs good and want to advertise it but can't find the serial #. Where is it?
Red
02-07-2004 05:34:01
 Re: 10-20 Serial # location? in reply to Cory Vellinga, 07-17-2001 10:40:43
What condition and how many dollars are yo asking for the 10-20?
Bob Kerr
07-17-2001 16:55:45
There should be an aluminum tag on the "firewall" just under the large fuel tank. If all you see there is two holes or two rivits then you can look for a raised pad cast into the left front side of the engine block.it is close to the water inlet elbow. It should have the original serial number stamped into it if the engine was never changed.You may have to scrape it off good to see the numbers.
Dick (IL)
07-18-2001 12:28:48
 Re: Re: 10-20 Serial # location? in reply to Bob Kerr, 07-17-2001 16:55:45
The '29 10-20 that I had years ago (KC166635) had the serial number stamped on the side of the block on a raised pad just below the top surface (cylinder head). Seems like it was on the RH side, all the way at the rear.
