6v to 12v system
BD
02-24-1999 19:56:02
I was wondering if I need to change the ignition switch on my Farmall SM to a 12v one once the I change the system over to 12v. Im getting many answers on this from yes to no. Anyone know for sure? I personally would be more concerned about the change in Amperage more than voltage on that switch. Would I also half to drop the voltage to the gauges with resistors? Thx.
BD
zman
03-03-1999 20:24:18
 Re: 6v to 12v system in reply to BD, 02-24-1999 19:56:02
Instead of the resistor route, simply change the coil to a 12V. You will be glad you did. Replace the bulbs, you can get them at any auto parts store for under a buck.
Phil Auten
02-26-1999 04:11:44
BD, The other thing you'll need to change is the
lights. You'll need to either replace the lamps
or get whole new light assemblies for the
headlights. The gagues may be lighted too, so
don't forget to check them for lamps too. (I'm
not sure about the gagues being lighted, but check
anyway, it couldn't hurt).
Good luck,
Phil
Bob M
02-25-1999 04:47:20
Your existing ign switch will work fine on 12 v. The ammeter will work on 12 v too, though you'll need to reverse the connections on it if you change to 12 volt neg ground. SM Oil and water temp gages are mechanical - they're independent from the electrical system.
Bob M
Craig
02-24-1999 20:36:33
Your switch that is 6V will work just fine on a 12V system. I never change them out when doing a conversion.
BD
02-25-1999 17:28:36
 Re: Re: 6v to 12v system in reply to Craig, 02-24-1999 20:36:33
Thx Gentleman. I did look at the Oil and Temp gauge earlier today and noticed they are mechanical..DUH on my part, I just never looked ;0) Thanks again..
BD
