'46 H-Hole in oil tube. Dumb ? but need ans
DaveZ
07-07-2001 16:31:59
The 1/4" tube that goes from one side of the head to the other, over the rocker arm. Mine has a hole towards the end of motor. It doesn't look it was drilled but more like its been filed or groung . Is it supposed to be there and if it is what is its function, since the rocker arm is getting a good dose already? Also how do I know if my valve guides need replacing?
John
07-07-2001 20:09:17
 Re: '46 H-Hole in oil tube. Dumb ? but need ans in reply to DaveZ, 07-07-2001 16:31:59
I'm working on a W4 engine and it has the same tube and today I called the IH dealer and was told that is a breather tube. I called cause of the hole so I guess they all have it. Did you rebuild the engine or at least have the head off? I found a copper "O"ring in the headgasket kit (after I had the head torqued down) and I don't know what it is. Do you?
Kendall
07-07-2001 16:52:17
One sign of valve guide wear is the engine smoking when you crank it but goes away real soon.
Ace Schrunk
07-07-2001 16:46:29
That tub goes to the air cleaner and the hole should be there to help burn the gases in crank case. And on top of head
