Follow-up on points and starter
Rob in Wis.
07-05-2001 12:02:42
As suggested I took the starter from my Super C in to be rebuilt. A sidelight of this is that it allowed me to access the flywheel so I could line up a distributor cam lobe to gap the points.
When I pulled the starter I noticed that the teeth on the starter gear and on the fly wheel were a little chewed. When I get the starter back those teeth will be new. Is that going to be a problem with the existing wear on the fly wheel teeth? If so, what are my options?
gene b
07-05-2001 20:31:14
 Re: Follow-up on points and starter in reply to Rob in Wis., 07-05-2001 12:02:42
the chewed up teeth on the ring gear is why the starter wont work good you would be better off with a rebuilt starter that way you would have a new drive the drive alone is 30 exchange but you need a good ring gear you will find this out the bad teeth on the ring gear will spoil a new bendix
Andy Martin
07-05-2001 13:22:58
A "little chewed" sounds OK. If you have a bad chip or missing tooth on the ring gear I would be concerned, otherwise jsut run it.
Rob in Wis.
07-05-2001 19:22:49
 Re: Re: Follow-up on points and starter in reply to Andy Martin, 07-05-2001 13:22:58
Great! With any luck I'll be up and running by noon tomorrow.
