Farmall B width
Steve K
07-05-2001 08:36:03
What are the widths a Farmall B rear wheel adjusts to? I am looking at one and the trailer I have has sides that I think are 6 foot wide, would it fit? Thanks Steve.
Steve K
07-06-2001 06:54:28
 Re: Farmall B width in reply to Steve K, 07-05-2001 08:36:03
Thanks for all the responses. I measured my car hauler and it was 76" so I doubt that It will fit even in the narrowest adjustment. Probably parts of the dished wheel would be in the way of the trailer fenders.
gene b
07-05-2001 20:36:46
it isint the width of the rear tread iiit is out side axle to outside they stick out past the tires
Jim Becker
07-05-2001 19:31:46
Yes what Dave said. However, unless you have the smallest size tires, you won't be able to set to the narrowest setting.
Dave BN
07-05-2001 15:44:15
Steve, the rear wheels are adjustable in 4" increments (2" each side) from 64" to 92". I believe that is measured from the center of the wheel as they don't know how wide of tires your going to have. Adjustments are made by bolting the lugs of the wheels either on the inside of the hubs (Narrow) or the outside of the hubs(Wider). You then swap the wheels from one side of the tractor to the other (notice that the lugs are not centered on the wheel. The 3rd width adjustment is made by turning the hubs inside out(dished in or out). Combinations of these 3 adjustments give you 8 different widths. Sorry if this is more info than you wanted. Dave.
Fred Tx
07-05-2001 10:09:47
It will fit on a 7 ft wide trailer. My trailer is 6'3" and it was a no go for my B.
Red Dave
07-05-2001 09:08:43
No. My B is adjusted almost as narrow as it can go and I think it is about 78 inches. It will not go between the wheel wells of a standard 75 inch wide car trailer. I had to find a trailer that had the bed above the wheels to get enough width.
