Help! Can't get crank pully off my 48 Cub, What's the secret?
Author |
Shawn B.
07-03-2001 08:40:46
I don't have the service manual for my Cub and I haven't been able to get the crank pully off so that I can replace the front seal. Any help would be greatly appreciated. Thanks, Shawn 909-699-1831
John
07-03-2001 14:51:32
Re: Help! Can't get crank pully off my 48 Cub, What's the secret? in reply to Shawn B., 07-03-2001 08:40:46
Shawn. These are usually a tight fit. You will need to find a bearing separator or some type of plate to put behind the rear flange of the pulley. If you try to use a gear puller without this backing plate, you will likely break the pulley. You will also need a large two or three jaw puller and a breaker bar and socket. You can heat the pulley up a bit but not too much. As you tighten down on the puller, take a large hammer and tap the bolt-head on the puller with a healthy blow. THis impact helps back the pulley off. When you reinstall, take some emery cloth and polish up the crankshaft where the pulley slides on. Also polish up the inside of the pulley. Use a little oil to reduce friction. You might want to heat the pulley up again and use gloves so you don't burn yourself. John
Dave t
07-03-2001 15:24:05
Re: Re: Help! Can't get crank pully off my 48 Cub, What's the secret? in reply to John, 07-03-2001 14:51:32
Is this the same advise for the Farmall A (113) engine???? I have to do the same job..
Jim Becker
07-04-2001 06:37:58
Re: Re: Re: Help! Can't get crank pully off my 48 Cub, What's the secret? in reply to Dave t, 07-03-2001 15:24:05
Yes, except some early A pulleys had a setscrew that needs to come out first.
Red Dave
07-03-2001 16:00:36
Yes, The pulley on a C-113 engine comes off the same way.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
1935 John Deere BN History - The History of My Tractor - by Alexander G. Knox. My grandfather, Orval A. Knox of Chandler, Arizona, affectionately known as Pa, purchased this tractor new from the John Deere/Caterpillar dealer (now Arizona Machinery) in 1935. It was his first new tractor and his first with rubber tires. He used it on his farm growing cotton, alfalfa, corn, wheat, milo, barley, and oats. My father, Norman L. Knox, recalls Pa putting a mower on the tractor during the day and then
... [Read Article]
Latest Ad:
11-2-34 tires
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
