300 Fast-Hitch
charlie
07-02-2001 21:13:06
I recently purchased a Farmall 300 row crop. It is equipped with a Fast-Hitch. How can I hold rear mounted implements at a constant and consistent height? I thought it should be equipped with some sort of adjustable cylinder stop to allow for lowering and holding at a consistent desired level. Any ideas?
Farmer Bob
07-02-2001 21:57:05
 Re: 300 Fast-Hitch in reply to charlie, 07-02-2001 21:13:06
Charlie, On my 400 Fast Hitch there is an adjustable cylinder stop that can be set to any position on the shaft to stop the cylinder movement you desire. Visit any Farm supply or hydraulic shop and they should be able to fix you up. Only thing they will need is the diameter of the shaft.//FB
