656G Hydro PTO slips
smirkey
06-29-2001 12:15:48
We are done with summer work and want to fix the tractor PTO. It slips when cutting heavy hay or even when engaging the baler. It had been fixed before by two "local" shops. about 10yrs ago new discs were put in,but it slipped a few years later. the second guy supposedly rebuilt the hydraulic pump. i'm thinking of pulling it myself and driving it 150 miles to a dealer. any suggestions what may be wrong, or how to diagnosis? how do i remove the unit? any comment or help will be appreciated. did i mention i'm poor because of the gas bill for operating the thirsty thing!!
rich
06-29-2001 20:48:43
 Re: 656G Hydro PTO slips in reply to smirkey, 06-29-2001 12:15:48
check the rod coming out of the pto that engages it if the rod is loose there will not be enough pressure . I think there is a small hole in the rod portion under the boot where a punch can be used to be sure its tightened. make sure the rod is tight.
