Can a Super MTA handle a 12ft disk?
GooseCreek
06-19-2001 08:24:57
I have my eye on a 12ft. disk for my SMTA. The land I work (6 to 10 acres) is mostly light sandy ground. I currently have a 10ft. disk. Is the 12ft to much for the SMTA?
John In Iowa
06-19-2001 20:34:10
 Re: Can a Super MTA handle a 12ft disk? in reply to GooseCreek, 06-19-2001 08:24:57
Overhaul my 400 about 6 years ago and put in 4 1/8 high dome pistons in it. Got 15.5 tries on 14" rims on the back and if I put a 1000 lbs. of weight on the rear, it handles a 13-foot JD disk with 18” blades with no trouble.
John In Iowa
john d
06-19-2001 12:05:14
We farmed for years pulling Kewannee 11' disk in 4th gear with an M. Pulled it with the SM in 3rd gear because 4th was too fast! A good SMTA won't even break a sweat with a 12' disk.
George
06-19-2001 13:55:04
 Re: Re: Can a Super MTA handle a 12ft disk? in reply to john d, 06-19-2001 12:05:14
It depends how deep you pull it. my 450 Gas (in good shape) will pull a 12'6 JD aw disc with 18" blades BUT it is a struggle when you put it all the way down in heavy soil,I have to use 1st gear so I pull it with my J.D. 70D.With so little acres you should have no problem if you "feather" it some, and you like to here her "Work", luck!
the tractor vet
06-19-2001 22:56:08
 Re: Re: Re: Can a Super MTA handle a 12ft disk? in reply to George, 06-19-2001 13:55:04
My S/MTA will pull my 2300 AC 13 and a half foot with 20 in. bellsand run all day in third high not quiet enough poneys to get forth
Denny Frisk
06-19-2001 13:45:18
Actually Dad's SM-TA did a real good job with his Kewaunee 12-1/2 ft. disc. The 14 ft. Krause was a little TOO big, esp. in plowed ground. The SM-TA with the 12 ft. was a third gear onlt deal. When He got the 450 We could disc stalk ground in 4th sometimes.
