Whats an MD Farmall Worth?
Zach Bender
06-09-2001 21:09:20
I am curious on what MD Farmalls are worth, in all conditions. I'm in the process of buying one but haven't seen it. Thanks, Zach
tm
06-10-2001 12:07:10
 Re: Whats an MD Farmall Worth? in reply to Zach Bender, 06-09-2001 21:09:20
Check out equipment trader online,
you can find lots of tractors there.
www.traderonline.com
tm
06-10-2001 12:04:45
Matt Sheaffer
06-10-2001 09:49:57
I seen Farmall MD's from $500 to $5,000.
Haas
06-10-2001 05:49:03
Worth, as with any old tractor depends on the condition. If running and no obvious problems, the MDs usually bring a little more than the gas Ms. That is because there are fewer of them. However, beware of any problems with the diesel engine. Parts are difficult to find and expensive. I paid $900 for a non running but not stuck MD about 18 months ago. Fortunately, I did not have to do any work on the diesel engine, it just needed cleaning up and work on the gas carburator and the ignition. For Chassis parts, they are mostly the same as the gas M. If the MD you are looking at is in good running condition, etc. $2000 would be a good price. If it has been restored or is in exceptional condition, the price will go up from there.
Steve Klein
06-09-2001 21:24:06
Could be worth up to $3800-$4000 depending on condition. Most are worth less than that. Be careful of the cyl head on that tractor. Cracked heads were a problem. We used to have one.
Garidgerunner
06-10-2001 06:05:22
 Re: Re: Whats an MD Farmall Worth? in reply to Steve Klein, 06-09-2001 21:24:06
Steve is right about cracked heads. A rebuilt head could cost $700 or more. Also aftermarket sleeve sets are harder to find than for gas Ms.
