Sick ih 4586
jeff
05-26-2001 20:06:16
I need an engine for my sick tractor.a v-800 IH diesel, any info would be helpful on this engine or any other that may in the 4586 frame thank-you in advance
George 2
05-27-2001 05:54:36
 Re: sick ih 4586 in reply to jeff, 05-26-2001 20:06:16
If you want to keep it original I would search the old truck wrecking yards. A few were put into the large trucks in the 1976 to 1980 period. They
were not popular as they were expensive to fix and had a higher than normal major components failure rate. The N series Cummins swap is a common swap both in the truck and the tractor.
tommyw
05-26-2001 21:49:29
id put a cummins in it ,thats a fairly common swap.the ih dv 800 is not a very good engine.
