What oil weight for transmission, torque PTO
goosecreek
05-24-2001 09:21:38
Finally got my SMTA running (stuck piston & cracked head). Now would like some help/recommendations on what type and weight of oil to use for the transmission, torque housing and PTO. I appreciate your help.
sammy the RED
05-24-2001 18:36:01
 Re: What oil weight for transmission, torque PTO in reply to goosecreek, 05-24-2001 09:21:38
I have two Super MTA's. HY-TRAN in both of them.
Like the others said, DO NOT use gear lube.
KURT
05-24-2001 12:58:05
I think SAE 90 weight would be the best. And you may want input from other guys just to be sure.
rICKb.
05-24-2001 13:13:40
 Re: Re: What oil weight for transmission, torque PTO in reply to KURT, 05-24-2001 12:58:05
Running gear lube in a tractor with a TA is not good practice. Hytran or its equivalent is best.
rich
05-24-2001 15:56:05
 Re: Re: Re: What oil weight for transmission, torque PTO in reply to rICKb., 05-24-2001 13:13:40
the heavy oil will not lubricate the needle bearings in the ta and also the spring loaded plungers that push the rollers in the cam to prevent the TA from going backwards when in low range may bind. use a good oil like hytran or a recommended oil from another source such as quicklift from cenex.
Red Man
05-24-2001 10:21:23
Use Case-IH Hy-trans in all 3. That's what I use in mine.
