Proper Torque Specs. for Manifold and Head on a Farmall C
Fatback
05-23-2001 20:23:03
I am going to remove the head and placed new rings in my "C", also going to do a valve job on it while I have it off. I am going to install a new manifold on it as well. I would like to know if any of you guys know the proper Torque Specs. to set the manifold and head bolts to. Thank you
Haas
05-24-2001 05:52:38
 Re: Proper Torque Specs. for Manifold and Head on a Farmall C in reply to Fatback, 05-23-2001 20:23:03
Don't know about the manifold. I had some leakage from the head gasket on my C. Folks on this forum said the correct torque for the head bolts was 65 ft-lbs. I asked the IH dealer and he said 80 ft-lbs. Don't know which is correct, but I tried 65 ft-lbs first. The bolts all moved at around 40-50 ft-lbs, so they were not tight enough. However, the leak did not stop until I went to the 80 ft-lbs.
Fatback
05-24-2001 10:01:51
 Re: Re: Proper Torque Specs. for Manifold and Head on a Farmall C in reply to Haas, 05-24-2001 05:52:38
Thanks HASS, I want to put her back together this weekend and test her out. Had some oil in the radiator not much just a skim, hopefully it was caused by a bad head gasket. Did not have any water in the oil. Sleeves are in very good shape honed them and installed new rings. Everything else seems to be alright as of now. Thanks again "Fatback"
