Grrrrrr. Got One H Wheel Weight Off
The Red
05-19-2001 13:45:30
HOT DOG! I found a technique that worked quite well. My tendonitis wasn't about to let me pound on those bolts and nuts for very long. I started with a 6 ton hydraulic jack and set it between the bolt/nut head and the side of the drawbar. After breaking the jack (20 years old) I got a 12 ton jack. I would have used a 20 but there is only about 9 1/2 inches of clearance. I pushed out the wheel weight about 1/4 inch then rotate the tire and push out the next one. After I had the weight out 1/4 inch all the way around, I removed the nuts and pushed each bolt/wheel weight about another 1/2 inch. On the third revolution, I pushed the end of the bolts to the hub. I then was able to pull the weight off. You might have to set your jack so the plunger is hanging down low so it will get oil to jack.
John In Iowa
05-20-2001 08:14:22
 Re: Grrrrrr. Got One H Wheel Weight Off in reply to The Red, 05-19-2001 13:45:30
Red,
When you go back together, Try some never seize just on the bolt that goes through the hub. May not want to put any on the threads because you may not be able to keep them tight.
John In Iowa
The Red
05-20-2001 08:50:24
 Re: Re: Grrrrrr. Got One H Wheel Weight Off in reply to John In Iowa, 05-20-2001 08:14:22
Thanks for the tip John. Good luck on finishing your planting!
John In Iowa
05-20-2001 09:38:37
 Re: Re: Re: Grrrrrr. Got One H Wheel Weight Off in reply to The Red, 05-20-2001 08:50:24
ITS raining again.
ThatOtherGuy
05-19-2001 18:38:34
That rim looks like a Case--from the hub, if it 'steps' down 1 its a Case. If it 'steps' down 2, its a Farmall. Got 1 Case and 1 IH on my SC.
The Red. Both Ways
05-20-2001 03:49:20
 Re: Re: Grrrrrr. Got One H Wheel Weight Off in reply to ThatOtherGuy, 05-19-2001 18:38:34
It depended on the rim width. Old Red H at the farm has 9 inch rims so it has the two step. Indy H at the farm has 10 inch and they have the one hump and then the slope before it flattens out. Old Rusty has what appears to be 11 inch rims so the slope is fairly flat. I looked through the H Photo Archives and both styles of rims appear in the pictures. I do know these rims have been off because the rim clamps are on backwards.
Excellent Idea....Tyler (MD)
05-19-2001 17:11:17
Humm....I should have thought of this while I was spending 6 hours removing the left and right axles out of the Super A. Maybe this idea could somehow work with this?
third party image
Tyman
Paul Shuler, thought of you ole rusty today
05-19-2001 15:39:32
Found an H today that looks very much like old rusty setting behind a vacant house on the north side of town. Didn't have the fenders but did have a 3 point hitch. Not sure how to find out who the owner is. Think it would be a good find for the right price.
Bob in Southwest Iowa
05-19-2001 15:12:21
Knew you would figure out a way!! Looks like it worked very well. Nice bright blue jack too!!
Dick Davis
05-19-2001 16:07:57
 Re: Re: Grrrrrr. Got One H Wheel Weight Off in reply to Bob in Southwest Iowa, 05-19-2001 15:12:21
Red, watch what you label pictures. There are young farmers present. Like i've told you boys in the past, "a program of monthly wheel weight rotation will, in the long run, prevent these major headaches" Glad you are winning. Dick
The Red
05-20-2001 01:26:19
 Re: Re: Re: Grrrrrr. Got One H Wheel Weight Off in reply to Dick Davis, 05-19-2001 16:07:57
Oops on that link title. I was just happy to get those weights off. I bet they have been bolted there for 59 years.
