Condensation/moisture buildup at carburetor/manifold
greek
05-17-2001 08:43:51
Just finished overhauling my MTA. When running, I noticed condensation (moisture buildup)above the carburetor at the throat going to the mainfold. What would cause this? The tractor seem to be running great. Do I need to adjust the carburetor or air flow somehow? I would appreciate any or all feedback.
Bob M
05-17-2001 10:03:00
 Re: Condensation/moisture buildup at carburetor/manifold in reply to greek, 05-17-2001 08:43:51
Greek - Condensation on the outside of the carb throttle body and lower end of the manifold is perfectly normal under humid conditions - especially when the motor is cold, ie. when first started. In cooler weather (50 deg and below) frost will appear in the same spots. Frost can cause problems inside the carb (carb "icing") making for rough idle, etc. until the motor warms up.
