What does it mean
john
05-10-2001 15:01:30
On my recently purchased Farmall M the tag says
"SM" under model,what does it mean? Also I am wondering what its going to cost to put new brake linings on? if anyone could help I would appreciate it!!
sammy the RED
05-10-2001 22:49:37
 Re: what does it mean in reply to john, 05-10-2001 15:01:30
SM = Super M
For the brakes, find a TISCO dealer and save about 50% on your parts.
Dan
05-10-2001 21:28:32
There should be a number on the right rear of the block, the M would be a 248 the super is 264. difference in the bore is the M is 3 7/8, super is 4", on the super you can go to 4 1/8 with oversize sleeves and pistons which makes it about a 282
Disk vs Band
05-10-2001 19:23:56
all except last few M's had band(and a few exceptions) and all super M's had disk brakes (round cast-iron housing) quite different types.. ralph
Bob M
05-10-2001 16:07:25
John - If the s/n begins with SM and is 3, 4 or 5 digits long, OR if it begins with an L and is 6 digits long, it's a Super M. Also look at the date codes on some of the larger castings (block, head, tranny, wheels, axle housings, etc.) If you find the last digit is an X, Y or Z, it says the parts were cast in '52, '53 or '54 respectively. This also indicates it's probably a Super M.
The Red
05-10-2001 15:04:12
John what is the serial number? That will quickly clarify if you have an M or Super M.
