Yep.
Get number one on TDC compression stroke. Loosen the distributor body.
Turn on the ignition and turn the body until the points spark.
Turn off the ignition and tighten the body clamps. Note the position of the rotor. The post on the distributor cap that lines up with that rotor position wires to the number one plug. Then in clockwise fashion, wire 3, 4, and 2.
