Finally got that transmission countershaft nut off my M!
Lowell Davis
05-04-2001 16:31:24
I finally got the countershaft nut off my transmission a couple of evenings ago. I picked up a 1/4" x 1" x 3' piece of steel and
drilled 7/16" holes to match the drive shaft coupling. Bolted it on and let one end rest on the floor to prevent the drive shaft
from turning. Then I put a piece of 1/2" x 1/2" x 1' stock in the countershaft nut's keyway, slipped a length of 3/4" black pipe
over that, and finally had the leverage to remove it. Bent the 1/2" square stock in the process, though!
Thanks to those who offered suggestions - since the ultimate solution was a little different, so I wanted to contribute it for those who might benefit.
The Red
05-05-2001 04:59:51
 Re: Finally got that transmission countershaft nut off my M! in reply to Lowell Davis, 05-04-2001 16:31:24
Lowell you take honors for unsticking one really stuck drive dog!!!
Haas
05-04-2001 17:05:45
Glad to hear about success! Probably the first time in 50 years that had been off.
