Final drive capacity.140
GEE
05-04-2001 05:57:32
I took off my 140's final drive covers (pans) yesterday to replace the leaking gaskets. Took 3 hours..boy I must be getting old. Of course, the left tire had to be removed, and the pans had to be degreased and cleaned. How much Hi-Tran do they hold..about a pint each..?? I don't want to pour it over the garage floor any worse than it is now. I usually use more oil-dry than oil. Thanks fellas....gee
Haas
05-04-2001 06:06:31
 Re: Final drive capacity.140 in reply to GEE, 05-04-2001 05:57:32
Why did you have to take a tire off??? Surely not to get the final drive pan off. Anyway, not sure how much the final drives hold, but what you do is be sure to put a new gasket and then reinstall the pans. Then fill up to the bottom of the fill hole that is on the inside of the final drive housings. It's located about the same level as the drawbar bolt holes and has a square recess to insert a tool to turn it. Some folks say to avoid leakage problems around the gasket (since the level is above the gasket of the pan) to fill only to just below the gasket level. If you use a new gasket and put some silicone gasket sealer on it, you should not have a problem.
