Sticking poppet (Injector) valves on TD6?
Rick from Paso
04-25-2001 23:23:44
I finally picked up some manuals (with the exception of the fuel injector manual unfortunately) for my TD6 at the Tulare tractor show and found some answers to my heat related missing and overheating problems. It seems my engine starts fine, runs for a while and then when it reaches run temp, starts to miss and smoke a little. A friend familiar with this tractor suggested a quart of transmission fluid in the fuel tank to attempt to unstick the injector valves. By feeling the injector lines, it seems two cylinders are affected with sticking injector valves. Any ideas out there? Where could I obtain replacements if the dextron doesn't do the trick? Thanks for your help!
Regards, Rick from Paso.
Roger
04-26-2001 16:01:32
 Re: Sticking poppet (Injector) valves on TD6? in reply to Rick from Paso, 04-25-2001 23:23:44
Rick, I know of two places that work on those old diesel injectors. They are as follows:
Central Fuel Injector Service
2403 Murray Road
Esterville, IA 51334
712 362-3567
DK Diesel Injector Service
1800 Fourth Ave SW
Watertown, SD 57201
605 886-2750
Roger
