SMTA Cracked Head
goosecreek
04-24-2001 09:41:41
I believe I have a crack head on my SMTA. The question is, will a regular "M" head fit on a SMTA? Thanks for your help.
artie
04-24-2001 19:12:15
 Re: SMTA Cracked Head in reply to goosecreek, 04-24-2001 09:41:41
It will fit but don't do it. You will have bent
push rods & maybe broken valves.
Charlie
04-24-2001 16:10:35
I'm not sure if the M head will fit but I believe if it does it will reduce you're horsepower. I think the increase in horsepower for the super series was in part due to a different head that allowed a higher compression. I'm sure we'll hear about it if I'm wrong.
jiM
04-24-2001 14:46:19
Hey Goose, Join the club, just found out my '41M has a cracked head too. I'm looking for a head and help as are you. What started out as a minor rebuild has turned in a $$$ nightmare.If you come across an M head let me know.
jiM
rich
04-24-2001 18:48:14
 Re: Re: SMTA Cracked Head in reply to jiM , 04-24-2001 14:46:19
Is this a low compression head? I may have one. This came off of an M that had the older style pto and I believe a 41.
jakee
04-24-2001 20:40:43
 Re: Re: Re: SMTA Cracked Head in reply to rich, 04-24-2001 18:48:14
all heads willi ter-change .but do not run the late model lp head with the 12000 ft hi alti-tude pistons,if in dout set head on and move one piston to top dead center ,them move one vale down .500 if nothing touches you are fine.also the early type kerosene heads are terible.
