B Pneumatic Lift
Jim
02-08-1999 07:51:13
I have a B with a pneumatic lift that is not working. The problem appears to be in the exhaust valve to the lift piston. I cleaned it up but it still does not operate correctly. The control level seems to have three positions. Does anyone know how this thing is supposed to operate, and what each of the operating positions of the control lever does?
Thanks
Clint Hofstetter
02-08-1999 12:58:13
 Re: B Pneumatic Lift in reply to Jim, 02-08-1999 07:51:13
Relying on my memory from 50 years ago, pulling the control toward you raised the implement, center position was at rest, and pushing it away from you lowered. As I recall there were some stops at the center position and one had to lift the control arm to move past the stop. Too many years ago!
Nate
02-08-1999 09:37:20
Being that you're referring to the lever and not the knob I'll assume you have the later arrangement. Forward should be 'lift', middle should be 'hold' and back should be 'lower'.
