IH A (1948) need info leak
John
04-15-2001 07:20:17
My A leaked coolant when I started it this spring. Its coming out through the acess hole under the fly wheel. I don't know where to begin. It starts and runs fine, but no coolant. Do I pull the head? Help
JOHN
04-22-2001 05:36:22
 Re: IH A (1948) need info leak in reply to John, 04-15-2001 07:20:17
Dave T ,you were right. Thanks for the reply. Hopefull to have it back together today.
John
John
04-22-2001 16:03:03
 Re: Re: IH A (1948) need info leak in reply to JOHN, 04-22-2001 05:36:22
To Dave T (or anyone else);
I split my IH A to replace one of the frost plugs.
I fixed that problem. The water leak (just above the clutch) made a mess of oily goo. Prior to spliting the A the clutch wasn't fully working. None of the goo got into the clutch as far as I can tell. I have cleaned everything as much as possible without pulling the clutch completely off. There was a lot of debris (goo) around the bearing which I figure to replace. Any suggestions about the clutch itself? I don't want to split it again in the near future. I should also mention that the clutch was working great prior to the leak.
Dave T
04-15-2001 07:35:18
I think perhaps you had a cold winter, and your antifreeze wasn't strong enough. You have a couple of frost plugs behind the block above the clutch. Regardless, you'd have to split the tractor to get at it and replace the frost plugs. It would be a good time to check condition of clutch and replace the pilot bearing too.....Dave
