Super A Oil Change
Sam
04-09-2001 15:03:47
Hi,
I need to change the oil in my Super A. It has non-detergent oil in it right now. I would like to replace it with detergent oil. Also the current oil is very thin and seems to have gas in it. Does anyone know where you can get an oil filter for a Super A. Please bear in mind that I am in Nova Scotia, Canada.
Thank-you.
David A
04-10-2001 05:48:54
 Re: Super A Oil Change in reply to Sam, 04-09-2001 15:03:47
Use 30 W detergent oil. Mine once got real thin and smelled of gas. I think that is due to short run cycles, cold engine, gas condensing on the cylinder walls and fouling the oil. If these are your normal operating conditions, I'd change the oil more frequently. May not need to change the filter each time.
David
George 2
04-09-2001 16:26:14
Go to your nearest Case IH dealer. There are 2 in Nova Scotia. One is in the Annapolis valley and the other is near Halifax. You can get their location and phone number from the Case IH web. Go to it and select "Dealer Locator". put in your postal code and it will give the name, location and phone number of the nearest dealer.
AGEN
04-09-2001 15:39:17
I got the filters for my A from NAPA. They even knew to ask whether I needed the star or umbrella type. (Tall or short) Most autoparts chains should be able to get them.
Kendall
04-10-2001 13:52:08
 Re: Re: Super A Oil Change in reply to AGEN, 04-09-2001 15:39:17
NAPA had brushes for my starter, carb rebuild kit, intake and valve cover gaskets, oil filter. No telling what else. And NAPA is everywhere.
Glenn (WV)
04-09-2001 15:33:39
Call Ken Updike at Carter & Gruenewald in Wisconsin. 608-455-2411.
Dave T
04-09-2001 15:15:44
Case/IH dealership. You do have those up there, don't you?, if not, then Central Tractor can help. You can even get them thru Napa.....Dave
